Maybe you need a better brand of Velcro. I use the hook side in the plane, and the loop side on the battery packs. If all else fails, get the heavy-duty stuff (also called 3M Dual Lock). The drawback with that is it's almost impossible to separate, and you may risk damaging your plane!
http://www.itapestore.com/index.asp?...n=Custom&ID=19
