RE: Downthrust on 50cc Extra 260
You can also do a rudder/aileron mix. This is also a standard requirement with most scale aerobatic planes. And you do leave both mixes on at all times.
As for pulling out on its own on the downline, this is again very common, correctable with a 1-2% throttle/elevator mix when the throttle is set at idle.
