RCU Forums - View Single Post - Thoughts on this.....
Old 02-19-2008 | 05:32 PM
KC36330
Default RE: Thoughts on this.....
ORIGINAL: mick15
KC I cannot agree with that, if one servo fails to idle you loose all the throw.
m
only if you strip one servo and it flops, in most failures they lock and with the servo locked the fulcrum point is just half with one servo operating, if you don't believe it just unplug one servo from the RX and give it a go, it'll cut the deflection by half. for every 1" of servo movement with one locked in a fixed position, the push rod will only move 1/2" but that servo will have twice the torque, it's called a 'Simple Machine' or in laymen terms a leaver
