ORIGINAL: MattyC-130
Changed over to the single piece tail cone. Runs about 30 deg hotter at idle and full throttle, but sounds and looks much better.
HELP!!!!!!!!!!!!!!!!!!!!!
I am on my 3rd starter motor. been going through some used JetJoe ones I acquired. I don't know if they were bad to begin with. I am using a 7.4V 2000MiAmp Lipo pack to power the pump and starter. The first 2 did fine for the first 2 or 3 starts then just died. Yes, the bendix clutch is adjusted properly no binding or spinning after starter disengages. I would like to try a different starter motor, but I have no clue on where and what to get, I would like it to be the same size so it will fit in my bullit starter cone.
Thanks in advance for the help
Matty
Matty,
Try a Graupner Speed 300 motor. They work well.
DW_Crash
