ORIGINAL: Hobbsy
Timmer, here's what the thing looks like in real life on a Fox .46, I scrounged through my, "I ain't seen it in a long time stuff" and there it was. I even found the Allen wrench I modified to tighten the rear mounting bolt. You screw the rear mounting bolt most of the way in and then slide the header over it then place the front mouning screw.
where did you get that header? and is that a diesel converson? how does it run like that?
