RE: Engine trouble
Sounds like you have a problem with your clunk line, its not touching the back of your fuel tank is it? If so the suction could be causing it to come in contact with the rear of your fuel tank. Thus restricting fuel flow. From your symptoms you have described, it does seem you may have a very tinny hole in your line.
