RCU Forums - View Single Post - How to do a proper Spektrum setup
Old 02-19-2008 | 09:31 PM
DanSavage's Avatar
DanSavage
Default RE: How to do a proper Spektrum setup
ORIGINAL: zadstar
Hi Dan,
How about wrapping the servo wires with thin Aluminum foil, instead of getting shielded computer wire? I wonder if that would work and save weight?
Regards
Serj
Maybe. But, I don't think you'll get the same effect. The aluminized mylar is only one component of the shielding. The other is the bare wire. It acts as an antenna to shunt any stray EMI signals to the receiver ground.
The shielded cable isn't really that heavy. It's only about 1/4" in diameter and the wires themselves don't weigh any more than a servo extension of the same length. So, the only extra weight is in the thin aluminized mylar, the bare wire and the pvc shell.
