ORIGINAL: Sukhoi4Me
Getting ready to order the gear for the Extra and I need some opinions.
I am wondering if 2 each per wing 5955s are overkill? I currently have 1 ea on my 50cc Sukhoi.
The alternative would be to go with 2 ea per wing 5985s.
Batteries. Not going the A123 route just yet. Will 2 2600mah packs for the servos and 1 2600 for the ignition be plenty?
And also, what length extensions and how many do I need?
i am using 2 5985's in the wing if u see the vid on the hare site kevin elder has all 5985s in his bird and the vid speaks for itself i will be usin 2 2300mah a123's with one on the ignition 10 flights no prob extensions
2 36 on elev
2 36" outer wing servo
2 24" inner
1 18" throttle
none for rudders
also will need 2 Y's for wings just program and hook em up
i would check out the videos on down on the deck on geometry and programming good stuff note on the wing servos tom is using 985's on his i believe he said they are fine so 5985's would be plenty
