RCU Forums - View Single Post - bladecx2.com extreme core upgrade problems
Old 02-20-2008 | 12:31 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: bladecx2.com extreme core upgrade problems
the extreme core components are a lot of rebranded parts packaged in thier own packaging. Do a search on the above mentioned website. I have the basic same parts all bought and shipped to the door for about 15 bucks (flybar, inner and outer shaft) Never have had any reason to switch to the blade grips and different blades. Mine flys like a champ and I am not experiencing any "list" to one side while in FF.
Do you have a lateral CG issue? Battery or something on one side that is heavier? If Ff and all momentum are relative to the cyclic inputs I would assume your side to side CG is off. Hold the heli by the flybar with the flybar running the length of the heli. If any lean to one side then you will know if that is the issue.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
