RCU Forums - View Single Post - strip aileron flutter avoidance
Old 02-20-2008 | 12:55 PM
bob27s's Avatar
bob27s
My Feedback: (19)
Default RE: strip aileron flutter avoidance
That is true - the not-so-sharp trailing edge tends to soften the effectiveness of the control surface around its center trim position. Forces the air to re-attach aft of the flying surface, rather than smoothly at the TE. That "space" is turbulence and drag.
No need to go nuts on most models. The 1/64 inlay helps you get a crisp straight edge, and provides "ding" protection -- ie, durability along with a fairly crisp edge.
But the molding and near-zero-thickness capability is why composite construction is popular for high performance designs. You simply can not get wood/foam that thin, and expect it to have any structural capability/durability.
