RCU Forums - View Single Post - Plane setup question
Old 02-20-2008 | 01:08 PM
Bob_S's Avatar
Bob_S
Default RE: Plane setup question
ORIGINAL: vanguard
When the engine is slowed to idle the plane tends to flare upwards.
You should be able to decrease the down thrust on your engine and solve the problem. You want your thrust angle such that the plane stays level no matter what you do with the throttle.
