RCU Forums - View Single Post - Engine trouble
Old 02-20-2008 | 02:36 PM
opjose's Avatar
opjose
Default RE: Engine trouble
He stated that "the engine runs fine on the first 3/4" of a tank.
He states that every subsequent TANK of fuel he runs after the first 3/4 results in the run-up sputtering....
"and then any tank after that it idels fine but sputters upon throttle increase,"
It sounds like his engine is mistuned, but the mis-tuning is only apparent once it has warmed up fully.
Since it is likely that it takes far longer than 2 minutes to run through the first 3/4 tank, that indicates to me, that once the entire engine crankcase ( and surrounding areas ) are warmed up, fuel is flowing a bit better, resulting in an overly rich condition.
So something related to the fuel line is likely the cause.
Maybe the fuel line is too thin, or restricted.
Once the entire area warms up the line becomes more supple and able to stretch resulting in much better flow.
Since this doesn't happen at the beginning, but DOES occur on each subsequent tank full, it is likely NOT related to the tank or clunk itself, but occuring somewhere between the tank and the carb, or at the carb intake.
