RE: Battery charging question
also if i remember correctly that charger is only capable of 2A charge rates, and may not even be able to supply that on the transformer that it comes with. I think that it is able to supply 2A on both sides if you run it off a car battery due to higher input capacity to the charger than the AC transformer is able to supply.
