Thank you very much for that info.
I have been flying a robbins 22 for a while now. I can hover it and fly it without crashing till the battery runs flat. Only time i crash it now is when flying out doors and it gets hit by some wind as it can not handle it at all.
I will make some adjustments to the controll tonight.
Set your aileron and elevator low rates to 70% and 20% exponential. If you aren't sure how, ask. Leave the rudder at 100%, no expo. Put the radio ailerons and elevators in low rate and leave them there. You won't be needing anything more for awhile.
And
Using the stock servo and gyro I'd recommend 65 and 75 rates for the tail. Start in 65. If the tail doesn't wag then try 75. More is better, you just don't want the tail wagging around.
Can you please explain this? I am pretty sure you are just talking about going into the menu on the dx6i but i just want to be sure.
Also any changes i make to this will this be reflected in Phoenix?
I can hover pretty well in phoenix but not perfect. The other thing. The throttle hold switch. Is that the switch i flick when i fly upside down it the sim?
