ORIGINAL: retard1322
I have that problam too on my bb it is becouse it is a buggy and it is rilly low to the ground and i have 10,000 Wtg dif fluif in my shocks and i still have that problam... and that S*** is thick. the shock springs are rilly soft to try puting about 1" section of fuel toobing on your shock shafts and that helps a lot. the toobing makes it look like the springs are harder... so put Rilly thick oil in them (and dont use moter oil... use silicone shock fluid)or silicone dif fluid becouse it is the same stuff as the shock fluid. and it comes thicker...) i use dif fluid becouse they come thicker than the thickest shock oil... and you can upgrade to the Alu. shocks i had to becouse one of my shocks was shot (striped and leeded fluid)
Hey, thanks dude!
Are the Redcat aluminum upgrade shocks much stiffer? Did you still have to use the 10K wt fluid in those also?
