RCU Forums - View Single Post - Installing Tailplanes- is there an easy way ?
Old 02-21-2008 | 02:18 AM
somegeek's Avatar
somegeek
Default RE: Installing Tailplanes- is there an easy way ?
Another thing is to check often when you glue up with epoxy. If it's 30 minute epoxy, check your measurements every five minutes or so. I've braced things to set up only to come back five minutes later and have things drift a bit off and needing adjustment. Keeping a close eye on your tail feathers to assure they set up correctly is well worth the time.
somegeek
