RE: timing mod with math
This will give how the piston moves up and down the stroke depending on crank angle. No you need to measure what distance from the top of the liner the piston is at TDC to get a reference point for that and then you use the value (P) to add and subract from that when you decided at what point a port opens after TDC for example.
I am not going to do the rest for you.
