ORIGINAL: kochj
Are you saying that if you take a long approach, and slowing bring in down you will loose it? Or you will have controll, it is just delayed?
THanks
Justin
As the plane slows down the fuselage acts as a wind break. This results in reduced and finally almost NO control over the elevator some time before the wings actually stall out.
At a slightly faster speed the air will follow the fuse back to the tail, giving you control.
What he is saying is that you come in a bit hotter, and at a steeper angle, then once over the threshold, bring down the throttle while holding it just over the runway until the plane settles in. This will be a steeper decent under power than what is normally done.
Typically with a steep decent you chop the throttle. In this case you don't want to. You need some power on.
