RCU Forums - View Single Post - Glassing
Thread: Glassing
Old 04-22-2003 | 01:05 PM
Shok's Avatar
Shok
My Feedback: (28)
Default Re: glassing
Originally posted by ProfLooney
Hi Shok you can check out my site here http://home.mchsi.com/~jahuntley/help.html look for the linkg glassing with Poly U. theres a big flow going to Poly U over epoxy these days as it is much easier and lighter weight not to mention a whole lot easier on your wallet.
Joe
Joe, you use Deft clear wood finish correct?
Thats it?
Your write up was very interesting, I think im going to try this.
One thing im curious of.
The contruction of the control surfaces on this plane do not lend themselves well to covering of any sort.
Im wondering if I can just put about 5 or 6 coats directly on the wood, wet sand then primer....will it give a good result?
