RCU Forums - View Single Post - Glassing
Thread: Glassing
Old 04-23-2003 | 05:59 AM
klhoard's Avatar
klhoard
My Feedback: (10)
Default Glassing
So the only reason you prefer laquer based vs. water based is wood warpage?
Specifically, I'm looking to possibly glass my next pattern plane. The wings and tail feathers are 1/16" contest bonded to styrofoam with polyurethane glue. I agree with you that this would not warp.
The fuselage is 1/8" contest balsa with formers every 12 or so inches.
I guess I could use water base on the sheeted foam and laquer based on the rest. Is there any difference once the water or laquer dries? I read on your website that the laquer leaves a gummy residue. How big a hassle is it to remove this residue?
Do you foresee any problems using 2-part automotive primer over the Poly U?
