RCU Forums - View Single Post - Nitro Models Pitts-40 Special Design
Old 02-21-2008 | 03:23 PM
  #50
linkadrip's Avatar
linkadrip
Default RE: Nitro Models Pitts-40 Special Design
ORIGINAL: vmsguy
I just received mine. I bought the Orange version.
I haven't dug into it too deep yet, just reading over the instructions (what there are of them) and getting ready to outfit the flight gear.
I know this is probably mundane, but what servos did you people arrive at using. I'm particularily interested in the aileron servos. They look like micro sized.
I want to order the servos, but I want to get the right ones. Ones that'll work well, won't strip gears too easily, etc..
Recommendations requested.
TIA
Lyndon
I bought Hitec HS81 MG miro servos for the Aieleron Servos. And use standard futaba S3001 for the elevator and rudder. Just got my new Tail Wheel For it And screwed up my installation got in to big a hurry should have came back to this thread to look at the pic again and installed it to far foward only buy about 1/2 inch but that was enough to cause it to not want to turn very sharp.
So if you do Change the tail wheel Gear make sure you get the tail gear wheel close as possable to the rudder. After messing up i just cut the wire that goes to the tail and made it a caster type wheel think it will work but its not connected to the rudder anymore.
Still have to hook up my linkages and mount the control horns for the Wings. getting closer to done. i'll take some pictures of my screw up so you can see what i mean about the tail wheel. [:'(]
I have 2 more i bought For other planes wont make that mistake again. There great tail gear though very impressed now my Twist's will get one but gonna be a lot more carefull how i go mounting and mke sure the piviot point is as close to the rudder as possable.
