RCU Forums - View Single Post - NP Ultimate Bipe/Cautionary advice
Old 02-21-2008 | 07:53 PM
dirtybird
Default RE: NP Ultimate Bipe/Cautionary advice
I found this model impossible to control when set up as the manual says. Ailerons movement 15 cm each way is way too much. I wound up disconnecting the top wing ailerons and reducing the bottom wing movement to about 1/4 on lowrate and 1/2 in on high rate.
