RE: Tips to align elevator/rudder pushrod holes
first find the height you want for your control arm if the fuse is covered use masking tape to draw your line. if it is a low wing you can just turn it over and lay the push rod on the bottom as close as you can to the actual location the rod will be in when running from servo to c horn mark where the rod leaves the fuse x should mark the spot if it is a high wing find center of the servo on the bottom. hope this helps.
