RE: CMP Zero Makeover
Worked on the tail wheel and rudder set up. Not sure this is going to work. I'm relying on the screw on the bell cranks and am not sure they will be secured enough. Wish I could figure out a way to weld the whole unit. Hopefully it will remain tight enough to keep the tail wheel in line.
Put the DA 50 on the nose and working to set it up. Will more than likely start on the tail assembly this weekend. Here are a few pic's.
MC
