RCU Forums - View Single Post - Balancing my Ultrastick 40
Old 02-21-2008 | 10:17 PM
vancouverman
Default Balancing my Ultrastick 40
Hello:
I am balancing my ultrastick 40. It has a saito 65 on the nose and came out pretty nose heavy. It will take 3 ounces of lead on the tail to balance it out. It this too much weight to add or should I go through the trouble to move the battery to the rear of the fuse? I did this with my last plane and had a hard time figuring out a hatch so I could remove the battery soI just sealed it in the fuse. I would rather just add stickon wheel weights to the rear near the tail wheel. Is this ok?
How much did it take you to balance your ultrastick?
Can someone recomend some high speed servos for the rudder and aileron? I see the tower pro servos on ebay for real cheap but am thinking they would fail and crash my plane so I would rather spend a few bucks more and get reliable ones. But not the expensive $90 gold plated ones...: )
Jay
