ORIGINAL: gokartingbob455
i think im obsessed with bottle rockets...lol
ok the way i fixed the c-hub problem didnt work.......
how do i get the part that goes into [link=http://redcatracing.com/itemdetail_part.asp?partno=02014]this[/link] out of it? im taking about the thing closest to the wheel.
The only thing that goes in that are the bearings which just pull's out or push them out with a small screw driver and the drive cup which you remove the hex nut by just pulling it straight off there's nothing holding it in unless you have the nut on it that holds the wheel on, then you slide that little bar out of the hole and pull the drive cup straight out then you can take your bearings out from there.
