RCU Forums - View Single Post - Balancing my Ultrastick 40
Old 02-22-2008 | 05:59 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Balancing my Ultrastick 40
I would move servos to the rear, starting with the rudder.
When I build an ARF, I install everything except the rudder and elevator servos. Then I check the CG. If it is nose heavy, I tape the rudder servo in front of the fin and try. If that doesn't do it, I tape the elevator servo on. Usually this does the trick, but I have had to move the battery.
I cut the hole in the top or side anf glue in a little piece of 1/16" ply or 1/8" lite ply, mount the servo and that's it. You do need a servo extension lead.
ID:	885740   Click image for larger version
