RCU Forums - View Single Post - OS 46 Prop nut problem!
Old 02-22-2008 | 06:03 PM
microsprint9's Avatar
microsprint9
Default RE: OS 46 Prop nut problem!
#1 never prime an engine that you are going to use a starter on #2 if using an electric fuel pump always disconnect the muffler pressure line to avoid filling the muffler and engine with fuel, if you are worried about spilling fuel get a small fuel tank that you can connect to the muffler pressure line as an overflow tank. If this is a brand new engine that you are breaking in on the bench i would get rid of the spinner and just use the nut, also heating the engine a bit with a heat gun can aid in starting a new engine.
