RCU Forums - View Single Post - ARC Jupiter
Thread: ARC Jupiter
Old 02-22-2008 | 07:57 PM
  #33
red head
Default RE: ARC Jupiter
WROB : Try keeping a little more RPM on on your landings. Also set the CG at 85 mm and it should work fine.
They do have a tendency to bounce a bit if you are to slow. I've owned a few of them and I really enjoyed them.
I never had a vibration problem either, but I never had a 4cyl on mine either, sounds like you may have a problem maybe with the prop or the way you mounted the engine.
As far as indexing the wing, if it's set in right and tightened tight, you won't have a problem. ENJOY !!! RED
