RE: Help with CP Pro swashplate.
hey ambravo,
to get that servo horn off you will have to remove the forward servo. just slowly pry it out of there with a screwdriver. it is held in place with double sticky tape. The tape should still be good after you pry it out so just press it back in firmly after you make your adjustments.
