RE: Throttle servo interferance?
If your sparkplug wire was loose enough to fall off that was the source of RF. The ground is dependent on the plug cap and with no where to go it was looking for the next available path to release energy. That was the metal cable. Running without a ground can make the spark come out the Hall sensor which tends to shorten its life to near 0. You got lucky and I'm happy for your good fortune. We all need some good luck now and then.
