RCU Forums - View Single Post - Help with CP Pro swashplate.
Old 02-23-2008 | 08:11 PM
evdreamer
Default RE: Help with CP Pro swashplate.
ORIGINAL: ambravo
Funny thing. That's exactly what I did late last night. Changed swash plate mix from positive to negative and BINGO, everything is moving as it should. Just took it up for my first test hover and she went up nice and smooth but she's drifting a bit, a little tail wag as well. Now its time to fool with the Gyro and proportional pot settings and finally trims. Does that sound right to you?
Anyway it was great to log on and find the solution to my problem posted even though I found it too late. THANK YOU!!!
Your welcome. Which way is it drifting? It is normal to adjust the gyro and proportional potentiometer. Once you have the proportional pot set you won't have to change it, then once it starts rotating in a direction then you know it is time for a new tail motor. I would have put it up sooner but I am slow at posting things. The flying characteristics are so much better with the DX7 and AR6100.
