RCU Forums - View Single Post - OS 120S-E PROBLEM
Old 02-24-2008 | 12:13 AM
kiwi two
Default OS 120S-E PROBLEM
PLEASE HELP HAVE A 1/4 SCALE HANGER 9 J3 CUB WITH A NEW OS 120S- E ENGINE INSTALLED AEROPLANE HAS 3 FLIGHTS
WITH 5 TANKS OF FUEL USED ENGINE RUNS FINE ON THE GROUND RUNS OK WITH NO CHANGE IN RPM WHEN HELD VERTICAL
ENGINE STARTS TO DIE AFTER TAKE OFF THEN PICKS UP AGAIN WILL FLY OK FOR A FEW MINUTES THEN STARTS TO DIE AGAIN
ENGINE IS INSTALLED INVERTED HAS A MPI GLOW DRIVER CONNECTED 16X6 CLASSIC PROP SIG 10% NITRO 1/2 CASTOR 1/2
SYN ,AND IS REFUELLED WITH A MPI REFUELLING VALVE THE AIR EXIT IS DOUBLE THE AIR INTAKE SIZE .THE IDLE MIXTURE HAS
BEEN LEANED OUT SO A SMALL AMOUNT OF WHITE SMOKE COMES OUT OF THE EXHAUST WHEN THE THROTTLE IS ADVANCED
ENGINE ALSO HAS A PRESSURE FUEL SYSTEM
HOPE SOMEONE CAN HELP
REGARDS KIWI TWO.
