RE: Tams Fail Safe No Jet Should be without
Hi Dave,
FWIW I found something funky with the Jet-tronic brake valve also on my 2.4 setups. I mix brakes to down elevator. If I mix at positive 100% the valve appears to work initially but then plays up but if I mix NEGATIVE 100% then all works normally. I am not sure if this has anything to do with 2.4 but I have not encountered this problem before on my 36 MHz models.
I wonder if these two issues are related.
Craig.
