RCU Forums - View Single Post - need help with prop size
Old 02-24-2008 | 04:26 PM
Missileman's Avatar
Missileman
Default RE: need help with prop size
ORIGINAL: rldrc25
First of all, I always get the best ''power" with A.P.C. props. They're simply more efficient. We
really need to know what airplane you are using. For example, if you are flying a high-winged
trainer with a flat-bottomed airfoil, you'll want a lower pitched prop for slower flight and landing
speeds. Most novice pilots try to land too fast! I know it can seem a bit complicated and it is
when you are trying to maximize performance. Think of it this way; lower pitch is like a lower
gear in your car, better acceleration but lower top speed and visa- versa. O..K? Don’t forget to
adjust the prop diameter to maintain a similar load on your engine. Good luck and fly safely!
You are correct.
Higher diameter and lower pitch=more torque and slower speed.
Smaller Diameter and higher pitch=less torque and more speed.
I don't know exactly what you mean by most power but I would guess you want more torque to get a bigger plane off the ground so I would suggest the larger diameter prop with lower pitch.
