RE: Fiberglass Fuselage question
there are two types of resin used in fiberglass fuselages,polyester and epoxy.[polyester type resin usually requires a gelcoat that is applied to the mold first then the cloth and resin.you may have this type and just the gel coat has cracked if this is a new arf I would contact the dealer for a replacement as repair is possible but not easy or pretty
