RE: PLEASE HELP WITH CX2 uncontrolable spinning
That means that the lower rotors are spinning faster. If it doesn't wobble then nothing is bent. If it does then I would guess it is the inner shaft or flybar. Is anything binding? Are the screws that go thru the lower rotor head and thru the outer shaft tight? If they are it might be rubbing on the inner shaft and slowing it down.
