3D Question
I think that we may both be right. I believe the correct definition for stall is that there isn't enough air moving over the wings to provide lift. Any sort of prop hanging manuveur could definitely be interpreted as the plane in stall (since you're using the thrust of the prop to keep the plane airborne). But there are 3D manuveurs that require speed.
