RE: Poulan 18cc porting?
P.S. More on the exhaust port... You will probably find that the bottom of the port will be about even with the top of the piston when the piston is at bottom dead center, especially if/when you lower the cylinder. Lowering the port any wouldn't help because then the piston would be in the way of flow.
AV8TOR
