RCU Forums - View Single Post - Tower 75 Running in.
Old 02-24-2008 | 11:40 PM
estradajae
Default Tower 75 Running in.
Hi Guys!
Well I think it's getting close in time the momen to first run my NIB tower 75... I was wondering if a scimitar 11x7 would be too small for breaking in the engine? I have an 11x7 and an 12x6 there, but I was thinking running it with the smaller one because I can rev it up more, and do the breaking in procedure that Dar Zeelon sugested...
Another fact is that I'm going to run it with zero nitro, plain castor oil.... Does this engine have more than one head shim that I can remove or should I leave it the way it is?.
Also I pushed tight the carb until I heard a click and was fully seated, opened the backplate to search por metal shards, none found.
It comes with a no brand glow plug, but I suspect it is the same super tigre glow plug..and heard that it will burn out at the end of breaking in....
Take a loot at the plane I'm building...it's not finished yet, but there are few things left plus covering...!! And I have to get a bubble cabin.... or make it, because I cannot get a molded one!! any suggestions?
Thanks a lot, Jorge
ID:	888055   Click image for larger version
ID:	888056   Click image for larger version
ID:	888057   Click image for larger version
ID:	888058   Click image for larger version
