ORIGINAL: thomasjohnmurphy
and one more (most important) point. MAKE SURE YOU POWER IS ON THE RIGHT MOTOR TERMINAL. If you get then reversed the gears will strip. The bottom termal is for power (red) the top is neutral (black)
You need to do a guide on upgrading the airsoft units.
