RCU Forums - View Single Post - Extreme composite Pro-Line
Old 02-25-2008 | 04:36 PM
  #224
StuartMellor
Default RE: Extreme composite Pro-Line
Hi TW,
Thanks for the tips. I would appreciate the position of the lead out holes -strange that these arn't moulded in on a glass fus.
Have use mini rear ele servos in my last 2 Oxalys & they work fine. Even better on the proline -the servos will slot into the roots on a ply mount & only requires a slot cutting in the lower surface. Should look neat. I would never use this system on a 4 stroke though -too much vibration. I also toyed with an electric version - but I doubt there is room in the undebelly for the battery & mounting the battery in the fus with no cooling is not an option!
Will certainly look into reinforcing rear of fus.
Many thanks
Stuart
