RE: Foamy
Well I ran too large of a prop (APC 8x3.8) which heated things up while I was torque rolling a lot and I believe may have impacted the performance of the speed controller (or I did not program it correctly). I'm using the GWS 8040 which keeps things nice and cool and I put in a thunderbird 9 and the plane is back to peak performance- now its more power management! The CPLR nano motor is about 3 grams heavier than the E-FLIGHT 250 but has a slightly larger ring to it. I'm still comparing the two; both run very well.
See you,
Don
