RCU Forums - View Single Post - Everything Radial Engines
Old 02-26-2008 | 03:47 AM
  #1223
the Gnome's Avatar
the Gnome
Default RE: Everything Radial Engines
Hi Kmot, jes, it's a fine model, but it is not mine, can't have everything, but I really enjoy watching (and listening) these radials in the air and on the ground too. The transmitter seems to bee a Futaba FX 28, I use a JR MC 24 and also hade such a switch on the stick. I used it to controll the flaps (it had three positions). Some time ago I then had a fault on the transmitter, when I moved the stick, it sometimes happened to move the rudder to full throw without having touched the transmitter controll. I found the wires of the switch had a faulty isolation, so that the switchs earth wire was connected to the rudder controll. After that I removed that switch again, just to prevent some crash and not to prove my good luck too much...
gnome
Holm und Rippenbruch
