Inner flaps (cont)
pic 1:
Parts used for the inner flaps.
Dubro #557 white plastic horn brakets screwed onto the flap torque rods.
The servo side gets two 4-40 ball/socket sets.
One socket on the bottom of the servo arm and the other socket on the top.
Last are two 4-40 clevises to connect to each plastic horn bracket.
I wanted to use ball/socket instead of the clevises but no room to connect the socket to the bracket via a hex head bolt.
pic 2:
The inside edge of each flap recess on the inner wing gets an enlarged hole to get the torque rod with attached horn bracket into the center wing.
pic 3:
As with the Yellow Texan, I'm using Robart's pocket hinges so the flaps can be removed for painting and future work.
(also still need to glass them).
pic 4:
There's not much clearance between the top of the servo and the servo arm so I put the hex head bolt in from the bottom side.
pic 5:
Set up complete.
All dry fitted.
As mentioned previously, I cut an access hatch in the bottom of the center wing so I can easily get to the flap set up.
I'll probably have to re-inforce those flap torque arms with some balsa and fixed gear straps.
A video of the inner flap operation:
http://www.rcuvideos.com/item/842QTK99S6T3RG76
pic 6/7:
My Bob Dively P-40 cockpit kit just came in.
That should be about it for all the major items when I start on the Yellow P-40.
Always nice to get all major parts before building in case something is no longer made or back ordered.
