RE: Custom Boat
Ah, so you are building more of a scale type setup rather than a FE setup. Sounds good.
With a 4Ah battery I believe you should see around a 20min (@ 12A) run time which is decent for a scale type setup.
Good Luck and post results
Ryan
EDIT:
I'd like to see a photo of the prop exiting the hull if you dont mind
