ORIGINAL: twtaylor
I can see where the back of the "box" could be hard to judge. Let me ask you this. Why put maneuvers in your sequence that requires that type of space cross box? If you're losing flying fields what is the purpose of making it even worse? If you're going to have cross box flying like rolling circles then don't down grade for flying out to far?
I don't have an argument, I only have questions. Why did the rules change? Seems to me they changed because guys were having a hard time flying inside the 75 degree box with the huge airplanes they built. So that begs the question what changed? The rules to fit the airplane or the airplane to fit the rules? In pattern we adopted the FAI F3A size standards for our airplanes. If we'd have removed those standards we'd most likely have the same problems as IMAC does now.
I applaud your work in IMAC, (I admit I've no clue what you do for imac) nobody gets the accolades they deserve for the work they do.
Reading these forums I see the same problems stated over and over.
I have an answer but you won't like it.
Then again I could just go away and not bother you.
So, what your answer that Ken won't like?
Bobby
