RE: Tams Fail Safe No Jet Should be without
Tam:
Does the Gear Failsafe work properly with the JMP Sequencer? I do not use 2.4 at this time, only 50 and 72.....Question I have is whether there is a conflict between the Sequencer and Failsafe since they both produce gear-up protection when the TX/RX are initially turned on.......
Is it just a hookup between the output connector of the sequencer and GEAR channel on the RX and a T-line to the master airpressure line, and then program?
Tom
