RCU Forums - View Single Post - What Does This Fuel Line Do?
Old 02-27-2008 | 01:20 AM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: What Does This Fuel Line Do?
No, it has to do with the carb mounting block. Most of the conversion type engines have them. They usually rotate the carb so the throttle is easier to hookup by using a carb rotating block that blocks the internal pressure pulse channel. Any carb you put on this engine will need this.
