ORIGINAL: 206driver
Anybody happen to be using an LBA -10 balancer made by Hyperion. I purchased one a little while back to plug into my Hyperion charger. Tried using it today getting fault indications. I just have the the battery running into the balancer right now. Due to a soldering of connectors problem I have listed in another post. What is meant by this is that I am not running the balancer through the charger I've just got the battery connected to the adapter board (thunder power) and that connected to the balancer.
When I plug them together the status lights for both battery types blink on and off for a little bit. Then the Lipo light blinks (four) times indicating that there is some sort of "connection or wiring error". I'm curious as to what type of wiring error could be occuring if I am using factory supplied wiring here.
The batteries have a frest charge on them using the charger alone.
Dave
If the cell indicator lights (one for each cell) all blink 4 times together and then the LBA shuts down it means the battery is properly balanced and needs no balancing.
